Jan 3, 2008 #1 A Antanio Guest Can some one tell me how to change the hole note setting from reading inches to mm. Thanks in advance.
Jan 3, 2008 Thread starter #2 A Alphonse Guest Hole notes use the units setting from the associative dimension style. The exception to this is if (on the Notes and Leaders tab) the "Use Part Units" option is checked.
