Change hole dimension from Radius to Diameter
  • Thread starter Thread starter wcwyder
  • Start date Start date
W
wcwyder
Guest
I have a Student Edition of Wildfire and would like to know how to change a hole dimension from a Radius to a Diameter on a drawing created from a 3D model? Is the Student Edition limited in this function?
If you single click on an entity that will give you a radius dimension, if you double click on the same entity (diametral/radius) and place it that will give you a diameter
Meaning you can't. You need to delete the unwanted radius dimension, and make a new one. It's annoying.
Do you mean a CUT I think HOLE features always show hole diameter. If its a cut the best thing is just dicipline yourself when you make the sketch to double click to produce a Dia dim instead of a radii. Then Show the dim on the dwg.
Here a cool tip
go to your CONFIG>PRO and add this if its not there
show_axes_for_extr_arcs YES
Then your cut feature and all arcs will have a datum axis inside them. Saves having to make a thru Cylinder axis
Thanks! I don't understand why this cannot be found in the included Help sections.
