Change default Chamfer & Fillet values?
  • Thread starter Thread starter Banegher
  • Start date Start date
B
Banegher
Guest
Is it possible to change the default chamfer and/or fillet values? It currently comes up at 2.0mm.
The default value 2 mm or 0.125 in for fillet/chamfer shows up only for the first time you invoke the command during an entire Inventor session. For all subsequent dialogs, the fillet/chamfer displays the MRUV (most recently used value). I don't think you can change the default values.
