Change color of multiple surfaces?
  • Thread starter Thread starter Antanio
  • Start date Start date
A
Antanio
Guest
Can any one suggest the easiest way to change the color of all the surface that I want at once with out individually selecting the surface and changing the properties.
Thanx
Hi Antanio,
Hold down 'Shift' key and select multiple faces and then change the properties.
Regards.
Don't use the normal Properties box in the upper right corner. You need to "reight-click" and pick "properties" for the pop-up menu
