Centerline width setting
VWwiz
On NX 11 I have gone through Drafting Preferences and changed the line width for center marks to .25mm and clicked "apply to all annotation." Now all my centermarks come in at .25mm as desired, but how do I change the default width for 2D and 3D centerlines to be .25m? They come in at .70mm.
Thanks for your help.
Try hitting the reset button located in the upper right corner of the 2D / 3D centerline dialogs, just left of the X to close the dialog. Unfortunately, this will completely reset the dialog and cause some areas to collapse and reset all other values until you actually use them once and press OK or Apply buttons.
Tim Flater
NX Designer
NX 11.0.1.11 MP4
Win7 Enterprise x64 SP1
Intel Core i7 2.5GHz 16GB RAM
4GB NVIDIA Quadro K3100M
As simple as that. Thank you! That fixed it. Greatly appreciated.
