Nope.
But you can apply a point or a csys or a vertex (or anything with x, y, z dimensions) back to a csys to the CG
Create an offset point from the desired csys.
Figure out the appropriate dimension names (d**) and write some relations:
d**=mp_cg_x
Not sure if the syntax is exact, best you check for system parameters in your help..
