In that reference 271828 suggested, look for 600S200-68 and 600S250-68. If the market only has 600S200-68 (some CFS manufacturers don't have the die or equipment to make 2.5" or 3" flange), then you could keep the same spacing and use 600S200-97. Because if you use an equivalent spacing, it'll be something weird like 14" on center. There's nothing technically wrong with that, but it's not standard and there is a high chance the spacing will be screwed up on site.
