kennyb04
- Jun 17, 2011
- 33
I have continuous beams running over columns (with shear only splices) which creates an inflection point within the beam over the column. My understanding is to not use the inflection points as the unbraced length with Cb = 1 but rather to use the entire beam span as the unbraced length and then increase the moment using Cb.
In calculating Cb for the bottom flange in compression, do you use both the positive and negative moment values in the equation? For example, if the maximum bending in the beam is the positive moment, do you use the absolute value of the positive moment or only consider the maximum of the negative moment (which would be at the column)?
Additionally, if for instance, the moments Mb and Mc are in the positive bending portion of the beam, but you are calculating Cb for the bottom flange, do you still use the moment values from the positive side of the beam or would you set any value from the positive side equal to 0 in the equation?
