Catia VBA startpoint, endpoint
Smileyoer
HU
Hello guys,
I have a question regarding is there any method which gives me a 3D line Startpoint and Endpoint?
I would like to check that if the line startpoint or the endpoint is closer to a selected plane. So I mean which distance is smaller.
I tried to put two points on that curve, but I got some errors because I dont want to create these points, just to check them.
Do you have any idea how to do it?
Thanks in advance!
Create the points, compute them but don't append them and then use SPAWorkbench to get the minimum distance between two objects (i.e your points and the plane)
Calin
