V
valtokrhm
Guest
Hi! Is it possible to give more than one sheet metal parameters in Catia V6 sheet metal?
I have two cases when I need it but havent managed to do it:
-Sheet metal part with different bend radius. For example 5mm thickness with 2 bends R5 and R10.
-Multibody part with different thickness sheets. For example welded sheet metal part that has 5mm and 10mm thickness plates.
With solidworks I can do all of this but I dont know is it possible with Catia.
Thank you,
Valto
Thank you,
Valto
