catia v5 to ppt: bom + image 2
MDesign84
Automotive
May 3, 2018
i'm looking for a macro that permits to obtain a powerpoint file in which there are:
1. an image of the part/assembly visualized on catia
2. a table contains a bom, in particular part description + part version/revision + material
3. that is able to make a ppt page for each catpart inside the catproduct
there is some macro about it, or somebody that know how to do it?
thank you.
Sorry is not weel described.
In every page of ppt must be the image and the table reffered to each catpart presents into catproduct.
Never heard of such a macro but I think know how to do it.
Calin
What you are looking for is too specific and I doubt you will find something like this.
I believe also that it is possible to do something like this and would take somewhere between 1-2 weeks of works.
if you know a bit of VBA and need help plz start posting and I will follow and help...
start with taking a screenshot of a part in catia (google it I've seen that before in forums)
then you need to understand recursive app in order to check all part in product structure (again google is your friend)
then find a recursive code to go throu product structure (again i've seen it on forums)
then you need to open each part in a product in a new window, take a screen grab, get info you need and put it in PPT.
Once you split each task it is not that difficult.
Go... search the web, try some stuff and post your problem. I will help (and I m sure other will join)
waiting for your first question
Eric N.
