Dec 10, 2021 #1 P pishva Guest in "generative sheet metal design" trying to change radius of flange , but it is disabled. how can i change the radius? catia v5-6R2020 Attachments www.jpg 110.4 KB · Views: 3
Dec 14, 2021 Thread starter #2 A arcturus Guest there is f(x) icon next to the value. value has a formula. click it and remove. Last edited: Dec 14, 2021
Dec 14, 2021 Thread starter #3 P pishva Guest arcturus said: there is f(x) icon next to the value. value has a formula. click it and remove. Click to expand... i cant remove the formula . would you please explain in detail? Attachments aaa.jpg 97 KB · Views: 4
Dec 19, 2021 Thread starter #4 A arcturus Guest clear `Sheet Metal Parameter.1\Bend Radius` from input area, click OK, then you should be able to change the value.
Dec 20, 2021 Thread starter #5 P pishva Guest arcturus said: clear `Sheet Metal Parameter.1\Bend Radius` from input area, click OK, then you should be able to change the value. Click to expand... when i try to do that , i get the error: Attachments 222.jpg 170.3 KB · Views: 3
Dec 21, 2021 Thread starter #6 M MrCATIA Guest To change the radius, you need to replace the linked parameter with a new value. 1. click this icon to erase the current link 2. type-in a new radius value 3. click OK
