CATIA v5 Drafting VBA Copy and Paste Between Views
kvu35
Aerospace
I am trying to create a macro that copies and pastes a drawing component from the background view to another view. So far I've tried this (not written perfectly, written for readability):
Dim bubble as DrawingComponent
Set bubble = CATIA.ActiveDocument.Views....Components.Item('Bubble1')
Dim viewToPasteInto as DrawingView
Set viewToPasteInto = CATIA.ActiveDocument....
Dim sel as Selection
Set sel as CATIA.ActiveDocument.Selection
sel.Clear
sel.Add bubble
viewToPasteInto.Activate()
sel.Paste
The macro pastes the bubble, but not in the desired view. It will paste the bubble in the original view: the background view. For some reason, sending the windows key command CTRL+V in subsitute of sel.Paste will give the desired outcome. That is,
sel.Clear
sel.Add bubble
' press CTRL+v
I've tried using PasteSpecial with all of the input parameters possible but nothing.
Selection.Clear ' just to be nice
Selection.Add ObjectToCopy
Selection.Copy
Selection.Clear
Selection.Add WhereToPaste ' in your case the target DrawingView
Selection.Paste
Selection.Clear
Eric N.
That works perfectly, thanks!
