Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
This was standard procedure in some companies due to the huge number of the parts in assemblies. Imagine when you have an airplane section and the software installed on your workstation has to check, eventually update (depending on settings) the links created by constraints....There are a few tools in the Analyze menu to help better understand how the assembly is constrained.
I know some users prefer to Fix parts (after they are moved into position) instead of using constraints. They don't have constraint errors, but they have to manually reposition the parts if changes are made.
v5? 3DX? In both of them, you have a dedicated command to analyze this issue. If you don't like it, create your own macro.IN CATIA COMPLEX ASSEMBLY DESIGN, WE OFTEN GET ERROR OF OVER OR INCONSISITANT CONSTRAINS. WHAT ARE THE REASONS FOR THIS, IS THERE ANY ERROR WINDOW WHICH PINPOINT WHAT THE ACTUAL PROBLEM IS ? CAN WE RUN DIAGNOSIS WHICH SHOW WHAT THE PROBLEM IS?
