Catia to Creo 1.0
  • Thread starter Thread starter bmwrull
  • Start date Start date
B
bmwrull
Guest
I have one big problem. I recive one 3D part made in
CATIA. When I open it on my PC in Creo 1.0 I see part in
3D. But the problem is when I made a drawing " I want to
see all diameters compleat sketch/drawing.But I can do
that I GET ERROR
1 Error: The saved view name FRONT does not exist in the
model PRT0011.PRT. The drawing view on page 1 could not
be created.
2 Error: The view on page 1 was not created because the
parent projection view was not created.
3 Error: The view on page 1 was not created because the
And second how I decide in 3D Part area "TOP/FRONT
/RIGHT"I thing this be a problem . Please look
enclosed file ( the picture ) 10-
31_105025_11111.jpg">31_105242_11111.jpg">
<a target="_blank" href="uploads/bmwrull/2012-10-31_105408_11111.rar" target="_blank">2012-
10-31_105408_11111.rar</a>
Edited by: bmwrull
I don't even need to look at your imported CATIA part file to know what the problem is. The fact that the file is NOT a native Pro/E file is the cause of your problems.
You will NOT be able to obtain any of the following:
1. No view names to show
2. No way to edit existing model dimensions
3. No way to show model dimensions on a drawing
4. No way to view part/assembly parameters
You will however be able to turn your imported CATIA file into a solid using import data doctor (if it did not already import as a solid model at translation time). Once you have a solid model, you can add protrusions and cuts. You can create any new parameters you desire.
Basically, your CATIA model will come into Pro/E as a dumb solid (or surface model). The ONLY thing that will remain constant is the csys of the base model. It will import into a Pro/E assembly at the csys without a problem.
Bob Schwerdlin
Design Engineer
Dukane Corp.
St. Charles, IL USA
If you use option Use Templates in Import Dialog box you will get defined views from your start template plus standard datum planes and so on.
sorry wrong forum
Edited by: dr_gallup
Ok thanks. I will try it tonight =)
