Catia Thick Surface Command Failed
  • Thread starter Thread starter amadali062
  • Start date Start date
A
amadali062
Guest
I thicket a surface in Catia GSD with thick surface command. The thick surface command failed to thick a surface. I want to convert my surface body to part with 9mm thickness
Could you plz tell what the possible reasons for failure in thick surface command
Many reasons why a ThickSurface command might fail: bad, discontinuous surface, surface has radii that are smaller than the thickness, surface folds over on itself, thickness too large, etc.
I don't know exactly what the problem is, so I can't tell you how to correct it. Maybe it would help if you could attach a picture (with the surface and tree).
Assuming it's the surface, I would delete the surface and make a new one with less curvature.
Just as a test, can you thicken the surface to the other side?
Another test: can you thicken with a smaller value?
