CATIA Macro & VB Projects Files
  • Thread starter Thread starter Pauras
  • Start date Start date
P
Pauras
Guest
Hi Friends,
I am Pauras a CATIA program developer. I have some projects and a huge collection of .CATVBA catia macro files. So if anybody interested in development then mail meI will send you all details about the project and help + guide + certificate fo excellance.
And if you need the macro file or project please PM me.
Feel free to ask any question regarding to CATIA PROGRAMMING.
pauras.desani@gmail.com
Hi Friend
Please can you give me advice or small help with VB macro. I tried to programmed small project and developted small robotic interface for my school excercise. V5automation describe creating joints at kinematics properly but this case doesn't work, please can you send me some macro that work and can create any type of joints.
Thanke you very much
Dear pauras,<?:namespace prefix = o ns = "urn:schemas-microsoft-com:office:office" />
I have the interest to work in catvba, I am having the experience in c,c++ and VBA with Autocad2000.
Please initiate to me. please send me the information,ii will do that.
Thanks&Regards,
Tharan
Hello Pauras,
I am interested to understand the project(s) that you have been working. Can you send the information to me regarding your accomplishments.
Thank you,
2gevad
Hi pauras,
Does CATIA v5 work with Visual Basic 6.0???
If yes can u please send me a small application to extract BOM of a product
Ashish
hi pauras,
please also tell me on how to get part/assembly position (X,Y,Z co-ordinates) in VB6
Ashish
Hello all and hello pauras,
I hope I don't come too late, i want to make some macros in Catia with excel interaction and I really need help. Now what I desesperatelly search is some code to learn how macros in Catia works.
Any recomendationa, code, or manualare welcome.
Thanks a lot
Does anyone know how to do something with Catia? OLE automation does not support Catia library types. you have to access Catia Document via "Catia.Application" object and implement various interfaces available. Specifially MECMOD and PARTITF. I would like to talk to someone who is VB6 hardcore to go in depth to develop some useful applications. Anyone out there?
Hi Pauras,
I'm new to V5 but lot's of experience with Pro/E. There was an easy solution for marcros ("Mapkey") and programming (Pro/Program). I'd be glad to get your stuff to get examples how to do this with V5.
Any recomendations, your code, or manualare welcome.
Thank you
Uwe
Cananyone tell me how to save the history of an assembly file-expanded mode(CatProduct file) in a text/ any other format which i can use to compare with a similar file.
Edited by: sujatha
Hello everyone and hello pauras,
Currently, I'm working on a project in CATIA V5 macro.
This aim is this one :
I Have a part (a wall)in witch many equipment are placed. My macro must be able to create automatically all the fixation points of each equipment and store the results (the points) in the part of the wall.
My macro work but the problem is that all the different parts are stored in a VPM tree and are placed in different level in that VPM Tree. My macro must be ableto work forevery project using a VPM Tree and that VPM Tree is always different in function of the project.
So my idea is to select all the lastest level of product, copy them, create a new CATProduct and paste them in order to have only one level of product. With this method my macro will run forevery projects.
But Have you any ideas to do this?
Currently I'm using this type of code:
Sub CATmain ()
Set MaSel = CATIA.ActiveDocument.Selection
MaSel.Clear
MaSel.Search("Type=Part*,all")
MaSel.Copy
MaSel.Clear
So, with this I can select all the part (witch are placed in lastest level of The VPM Tree) and after, I would like to select the parent witch is the CATProduct.
But I don't know how to select these lastest CATProduct.
Do you have any ideas about this?
Thanks in advance
Olivier
Hi
Neville Johnson here. CATIA V5 VB VBA VBScript PKT KWA Knowlegware Programmer
Hopefully I can help you with any programming related issues.
I can be contacted at nevjohnson@yahoo.co.uk
Olivier
Try using this code to get the product
Sub CATMain()
Set oRootDoc= Catia.ActiveDocument
Set oSel= oRootDoc.Selection
oSel.Clear
oSel.Search("Type=Part*,all")
For n= 1 to oSel.Count
Set oPartSelected= oSel.Item(1)
Set oPartProd = oSel.FindObject("CATIAProduct")
Next n
End Sub
Dear Pauras,
i am serching for a person like u from long back. i am very much interested in working with vb and macros. so please help me in this regard. waiting for ur reply.....
Edited by: juturu
Hi Pauras,
I need project and help + guide + certificate fo excellance
HiPauras
I am very much intrested in the material can u please forward to me
my mail id is deepu_abl@yahoo.com
Thanks in Advance
Hipuras,
HI Puras,
i am very much interested in catia macros, send me the help+guide+ certificates of exellance, my mail id arun.svr@gmail.com
hi pauras,
I'm having the exp. in c++ and vb ...... also catia v5 for last 3 years .... I want to work in macro programing .... please reply me for the same. My e-mail ID is sandeepbando@gmail.com
