catia composer black environment problem
  • Thread starter Thread starter fgh
  • Start date Start date
F
fgh
Guest
Hi,I import my catpart format model in catia composer and I see this black environment.
I don't know what is the problem.I reinstalled my catia composer but that is still there.can you help me please?
Change to a View and change the Background Color
thank you,I tried,it didn't work,it's still black
I have seen this when you are not running support / up-to-date graphics card drivers, for this you will want to check with your reseller whats the current recommended set up. One thing you could try is to go in the settings and set your profile to safe/high speed. Also under Hardware support check what you have selected and try changing it.
Hope that helps. You may also be interested in www.cadasio.com
thank you very much.after 4 days I tried almost everything and this finaly worked.thank you my friend.
No problem, glad it worked!
