Casting Bi-Metal Babbitt 2
act1
Materials
Cannot locate solidification shrinkage data for ASTM B23 Alloy 2 [Tin base] Babbitt. Does anyone have a quick resource or better yet..value. We static cast due to config. and want properly sized riser for new component [big - lots of babbitt].
If you can't obtain the shrinkage data, there is another option. You can use the information below to approximate volumetric or linear shrinkage for casting the babbit.
ASTM A 23 Type 2 babbit contains 88-90% tin, 7-8% antinomy, 3-4% Copper and less than 0.35% lead.
The following information was obtained from several sources that I have;
For pure tin, linear shrinkage is 0.6%, volumetric shrinkage is 1.2%
For copper, linear shrinkage is 2%, volumetric shrinkage is 7%.
I don't have specific data for antimony. Using the laws of mixtures, you can take for (tin) 0.9* shrinkage % + (copper)0.035 * shrinkage % and for antimony use a value similar to tin (0.075* shrinkage for tin) = shrinkage % for babbit.
