B
bhayden
Guest
I'm trying to get a parameter to display as part of a dimensions text. I created the parameter CSKDIA (type real_number) as a drawing parameter. When I bring up Info for the parameters it is listed with the correct value. I access the dimension text through properties and enter &CSKDIA. I end up with the actual text string &CSKDIA
If I enter one of the Drawing Lables like &model_name that displays the value of model_name correctly in the dimension text. I tried one of the other listed local drawing parameters by entering &PROI_VERSION as part of the dimension text and that displayed correctly also. I tried Designating CSKDIA but that had no effect (although CSKDIA is not a file based attribute in Intralink I wouldn't think that would be the problem.)
I entered &CSKDIA in a Note instead of as part of Dimension Text and that displayed the value 0.212 just fine.
What am I missing?
-Bernie-
What am I missing?
-Bernie-
