One of our engineers claims that you can not calculate do on these welds (the a3 and z3 weld in the picture).
Because the weld will not be X-rayed as a result there can be crack starters in these welds. He says that you need 3 things
to do calculations on these weld 1. Material data 2. Load on the weld 3. information on where
the imperfection are and it’s geometry. Is that statement true and if it is not how do i motivate that?
These structures are subjected to low forces, you have a high safety factor.
