redouane22
Industrial
hi friends i want your help please
if theres is an API Plan 54
API Plan 54 is Pressurized external barrier fluid system supplying clean liquid for an arrangement 3 pressurized dual seal. The barrier liquid is maintained at a pressure greater than seal chamber pressure and is circulated by an external pump or pressure system. and we have some leakage from the external fluid to the process fluid.
for information
we use dowtherm Q as process fluid and à mineral oil as barrage fluid at 200°c
for information
