Can any one tell me where to find Config.Pro and Setup.dtl Tools
  • Thread starter Thread starter 3Dpro
  • Start date Start date
3Dpro
Guest
I need a website where we can find the config.pro and drawing setup.dtl options and settings.
You can find hundreds of config.pro and drawing setup.dtl options and setting tools in the following link.
http://www.3dlogix.com/
Cpc 2.1.3
We at CODI (www.codi.com) have worked very hard to build a configuration application called CPC - Customize Pro/E Configurations, that enables you to configure all Pro/E variables, works in several languages, it contains help for all Pro/E variables, it allows you to search for a variable name, function, translated name ...
It allows you to remotely configure all Pro/E workstations in your network by sending all configuration files remotely,
it allows you to have different groups of computers with different configurations if you want, please see our website!
check: http://www.codi.pt/Dotnetnuke/Portals/0/Empresa/Home/Outros_PDF/Presentation CPC 2_EN.pdf
