S
sellandj
Guest
Hello, I'm trying to use an inheritance feature for machined castings in part mode rather than adding machining operations in assembly mode (mainly for chamfer/round functionality). So I create a part, insert inheritance feature, and make cuts, holes, chamf, etc to the part. Then, when I create the drawing for the machined part, is there a way to make a functional 1 item bom that shows the name of the model used for the inheritance feature?
Using WF5 (M100) or whatever it is called now
thanks
thanks
