A
Atropos89
Guest
I'm trying to export an assembly to STL. Some of the components in the assembly do not show up in the resultant STL file. If I try to export just those component parts to STL, the STL option does not show up in the "type" box on the Save As window.
Any idea why these files can't be exported as STLs? There is no difference in sources between the different files in this assembly. They are all import data from Inventor.
