Calculating nozzle load
  • Thread starter Thread starter jelston
  • Start date Start date
J
jelston
Guest
Can nozzle load be calculated in Pro/E or Pro/Mechanica?
yes, in fact any FEA software can do it (under the software limitations condition).
you can analyse the stress state in a pressure vessel and nozzel conection under, radial, tangential and circunferential forces and moments as stipulated in wrc 297, wrc 369 wrc 493 and wrc 107 (Welding Reaserch boletins).
stress must be keep under yield strenght to asume the lineal analysis that pro/mechanicalcalculates.
jeltson,
I might suggest you re-word your question. Are you looking to find out if Mechanica can calculate the load distribution given a fluid, in/out pressures and nozzle shape? Or, are you interested in finding out whether or not Mechanica can simply handle applying a pressure load, calculated by some CFD code or hand calculations, to the surface of the nozzle? If your answer is the first situation, then Mechanica cannot handle this as it does not perform any CFD analysis. Mechanica can apply pressures to analyze stresses and deflections in the nozzle.
I hope this helps,
Kaz
