CAITA SCREEN LOCKED
merium
Automotive
Oct 2, 2023
3
Hello all,
I have faced an issue on Catia V5, when I was trying to fix this problem showed below
I suddently cannot remove the error message even clicking on "OK" servals times, the screen remain blocked,
Is there a solution to this problem ?
Could you please inform us as to which workbench you're using and which feature you're trying to fix. A screen shot of the entire pop-up window would be very helpful for us to help solve you're problem.
The error message suggests too big of a diameter with too small of a bend radius. Can you modify the center curve to remove sharp bends?
Hi jack
im working on EHI/EHA harness Routine, the real problem is that the message sign wont disappear although clicking on OK several times, and im afraid that if I force catia to be closed and restart it , the project wont be saved.
thanks in advance
(oh, Wire Harness. I thought it might be Tubing)
try ESC to back out the error. Or CANCEL
There's a checkbox "Do not show this dialog next time", have you tried it?
hello guys,
no ESC or Cancel was working, I have forced the application to be closed and I lost all work,
cause when I tried to open the project in hope to recover the session, catia opened without that message for recovering
thank you
