E
e30solo2racer
Guest
Hey there,
I am trying to create a mechanism using an IGUS cable chain. (http://igus.kimweb.de/index.asp) I've set up the mechanism using pin connections with joint limits set at 0 to 30 deg. Before defining the joint, I aligned all the components to a plane to be sure that all the angles would be zero. After defining all the joints, I create a planer connection folded back on itself with the last link added joined to an offset plane from the first link. The point of this mechanism to to have the first link stationary while being able to drag the last link in a straight line making the radius of the bend in the chain a minimum. Let me know if you guys have any ideas.
