brick wall
  • Thread starter Thread starter jkb
  • Start date Start date
J
jkb
Guest
Banging my head against a brick wall.
I need to create a brick wall assembly which can be used in other assemblies. I need to be able to delete individual bricks without effecting patterns etc. Is there an easy way to create a quick and easy set of building blocks in a large scale assembly?
I thank you
sure!
create the brick.
pattern, and redefine as a pattern table.
this way you can delete individual bricks while maintaining all you ref pattern features.
f
hello
create a pattern of bricks
and then unpattern them
have you tried this?
xcad
the way i understand his question, he doesn't want to affect the pattern benefits.
pattern table is the only way i know to do this.
unpatterning would, for example, break any REF PATTERN ability.
f
hello
To be more specific
