Breaking a large table into multiple smaller tables
  • Thread starter Thread starter Guest
  • Start date Start date
G
Guest
Guest
Use the Pagination command, found under the Table menu.
Table > Pagination > Set Extent > Add Segment
When you add a segment, you can set the extent of that segment as well and go into 3 or more columns. If you go to the next page before you add a segment, the new segment will be on the next page.
