BREAK DIM LINES IN RADIAL DIMENSION
  • Thread starter Thread starter XICANDER
  • Start date Start date
X
XICANDER
Guest
In order to break dimensions lines. If you have to dim a radial dimension, for example r=1000, the auxiliar line always reachsuntil the center of the circle. Is not possible to cut this line? How do you make to dim a r=2000 radio into a DIN-A4 format? I can
Highlight the dimension and choose "Flip Arrows". Radial dimensions can be flipped 3 times.
