Box Culverts - Difference between ASTM C1433 and C1577
JoelTXCive
933
Is there a quick easy definition for the difference between C1433 culverts and C1577 culverts?
It looks to me like the C1433 culverts take an HS-20 load with a 24Kip 'design tandem load'.
Whereas the C1577 takes the HL-93 model (Comprised of HS-20 + 25kip design tandem).
Neither standard takes the design lane load.
Is this a good summary? If so, then why two standards. I must be missing something.
Thank you,
Joel
The ASTM Standard for the Standard Design Code is: ASTM C 1433 Precast Reinforced Concrete Monolithic Box Sections for Culverts, Storm Drains, and Sewers
The ASTM Standard for the LRFD Design Code is: ASTM C 1577 Precast Reinforced Concrete Monolithic Box Sections for Culverts, Storm Drains, and Sewers According to AASHTO LRFD
Also, you may find a note on the AASHTO standards M 259 and M 273 - “If load–and-resistance factor design is required, then use ASTM C 1577.”
Pretty much all states have gone to LRFD with HL93 as the design truck
I thought we always spec'd the C1577 ones, but we have an existing project's specifications that has 1 region of culverts citing the C1433 standard in our contract documents.
I think it was old contract language that somehow slipped by. We are trying to determine if we can keep the C1433 standard; or need to issue a change order to the 1577 standard.
I think it is better to keep your spec consistent with the design code, so as not to cause confusion.
