Hi all;
I've been tasked with ensuring that some large wood bowstring roof trusses built 40-50 years ago are reinforced and bought up to current Canadian design standards.
In particular, the strength of the glulam bottom chord is considerably lower than what's currently required. We've designed some high strength steel tension rods connected at the ends and supported mid span by wing plates similar to what's been done in this thread ( here.
Currently the plan is to apply tension to the rod to remove sag, and then tighten nuts on either side of the wing plates. Jacking the bottom chord up before installing the rod is unfortunately not an option.
My question is this: How should I determine the amount of tension force that should initially be applied to the steel rods? We're currently thinking that they should be pre-tensioned to 80% of the dead load force in the bottom chord, but we're still a little concerned about accidentally inducing compression in the wood. If we were to tension them to only, say, 10% of the axial dead load just to remove sag, is there any reason why they wouldn't still take snow and live loads in place of the bottom chord?
Any help or guidance would be appreciated - please let me know if anything needs clarification.
Thank you!
Engineer in Training
Thank you!
