Bottle desinflating
  • Thread starter Thread starter eltioseba
  • Start date Start date
E
eltioseba
Guest
Any clue how can I measure a deformation in a bottle that is desinflating from inside?
The bottle is closed and consumes internal air. I`m trying, with no success, to calculate the bottle resistance and changes.
desinflating from inside ?
Isn't it quivalent to applying a uniform pressure equal to the internal air pressure,
you ust know the value of this pressure. If the pressure varies with time do time dynamic analysis using vaying load equivalent.
Israr
I agree wight Israr, The best way to do it is to apply the pressure to the outside wall of the bottle from zero to 1 atmosphere is the bottle is expose to the outside. This can be done with a dynamic time analysis as Israr mentioned.
Luis
