Border line of rectangle not visible
  • Thread starter Thread starter Balin
  • Start date Start date
B
Balin
Guest
When I draw a rectangle by specifying a corner and drag it down to the second corner, I am unable to see the border line of the rectangle box around it. Where as when I double click on the rectangle box I am able to see the thick border line around the rectangle box. How can I can I get it to show the border line of the rectangle box?
Can any one tell me how to set right the issue.
With regards.
Hi Balin,
How about color line,I think you should set color line set to opposite with color back ground of monitor.
or try to post here your sample drawing i want to see it.
With regards.
I only thing I feel is that you might have turned off the layer of your viewport is turned on. If so then turn it on other wise you wont be able to see the rectangular box.
Enjoy.
