bonus tolerance
  • Thread starter Thread starter 9003189887
  • Start date Start date
9
9003189887
Guest
hi
can you explain what mean by bonus tolerance. with example
that one really helpful to me
regards
bala
Bonus tolerance is used in GD&T and allows one tolerance to vary according to another.
For example, a hole dimension is 10mm +/- 1mm and the center of the hole must be within a
hi molly
thankyou very much
bala:
Understand this one thing about True Position; it is very easy to apply a tolerance that is much tighter than necessary. As a quicky test, divide the Circurlar Tolerance you have by two. This will approximate the plus/minus tolerance. If it is too small to be practical, then increase the CT.
It is amazing to me how oftenmiss applied GD&T increases the cost of parts. "But, we used GD&T!" Well, you MISS used it!
Just think before you release.
Can you help me in few things.
please send me any PPT or file which clear GD&T problems.
srinivas.reddy@huscointl.com
i am very keen intersted in learningGD&T
i had doubt about projected tolerannce.
SrinivasR
thankyou roger
SrinivasR:
There are a number of books available and schools that can teach GD&T. A junior college in your area may be one of the better choices. Also, there are on-line classes to consider.
