Bond Joints
  • Thread starter Thread starter bem
  • Start date Start date
B
bem
Guest
I'd be interested in any techniques used to analyze bond joints (epoxy)
Especially rules of thumb for interpreting or dealing with the singularities caused by the abrupt change in stiffness where the two parts are joined
Did you end up finding any info on this topic? I'd be interested in this too...
Hello Ben,
What type of singularities is your model having problems with? Is the sofware giving you and error telling you that your model is insuficiently constraint ? Sometimes this error occurs if model have a very large discrpancy in stiffness between materials. This is bacause the stiffness matrix is ill condition.
Is the problem you refering about stress discountinueties between the two materials at the join? If that is the case this is not necessary a singularity but a physical manisfestation of the fact that the model has two or more materials sharing the same face. How much difference there is between the to poissons ratios of the materials? Did you run a multy pass adaptive (MPA) and make sure you it was a singularity ? Could tell me a little more about the problem may be I can help.
Luis
