BOM table is too long.
  • Thread starter Thread starter Murtazank
  • Start date Start date
M
Murtazank
Guest
Hi i am currently polishing up my GA drawing in creo parametric. i have too many components and my BOM table expands longer out of my sheet. i would like break the table into 2 sheets. is there a way to do that?
(creo)
Select your table tab then select the table you want to split
In the table tab, under the table sub pull down menu, select paginate
select where you want to split (select the find item number you want to end at) MMB
Sheet two will be generated and the table will continue with the find item number.
