Bolts
  • Thread starter Thread starter amd450
  • Start date Start date
A
amd450
Guest
I'm new about the Pro/e, but I would like of know if there are something or a command to do a head of a bolt.
mr. amd450 can you explain me your question breiefley..
I would like of modeling a bolt, but my question is if there are the way to do the bolt with only one command, in the Sketcher there are something to sketch a hexagonal?
Pro/ENGINEER is a feature based modeling system. Peo/E does not have any primitives built in. Each feature is unique and the user must create it. To create the bolt head try this.
Insert>Protrusion>extrude. Pick a datum plane. This will place you in sketcher mode. Use the tool icons on the right to sketch the cross section i.e. HEX or circle. Click the check mark. Enter the thickness of the head. Click OK in the dialog box.
Should take less than 1 minute to do.
YOU CAN SEARCH THE FILES SECTION OF THE SITE AND YOU WILL FIND PLENTY OF THEM
