elpa02
Industrial
- Mar 7, 2003
- 4
I would like to be adviced on two matters about bolts.
At first where can i find a table related with the alloweded torque load for each bolt dimension (e.g. M2,M4....)and with the strenght grades(3.6,12.9 etc).
There is a small pipe with internal thread at both ends.
At the one end it is bolted a bolt and at the other end it is installed a manometer.
The pipe is filled with oil.No leakages.If we start bolt the bolt the pressure shall be increased. How can i find the torque demand related with the pressure.
Can i start with : Torque =F*p/2 where F=the axial force
p=pace.
Thanks in advance
p=pace.
Thanks in advance
