bolted component faces
  • Thread starter Thread starter Eldon
  • Start date Start date
E
Eldon
Guest
I often find that I'm trying to model an assembly of two components (generally different material types) that are connected together under bolt preload.
I would guess that in an application with high bolt preloads and relatively low inter-component forces, it would be overly conservative to assume that the load is transferred direction through the bolt, in shear. Rather, I would say that the contact surfaces would transfer the load directly due to friction. Modelling this behavior in pro/e integrated mode is a pain because I can specify a contact surface but can't specify a friction coefficient, which of course is no good. Also, contact surfaces generally use up a lot of computing time.
For these reasons, I generally just use an end weld idealization on the connection surfaces. Does this make sense to everyone?
Also, what is the difference between end/perimeter welds and rigid connections?
Eldon/.
