Bolt torque-safety factor in member relation
takio
CA
Hello
When applying recommended torque from clamp manufacturer. (They said the clamp safety factor is 5, when using 109 ft lbs for 0.375 steel member.)
I get safety factor of 1.5~2 in members at bolt joint surface. but my requirement for the member safety factor is 3.
In this case, is this something that I need to worry about? because the manufacturer says it's ok to use the torque for 0.375" thick member.
or, is this something I just should go for a different clamp with less capacity, which means less preload.
I used FEA to see the safety factor.
Thank you
are you saying the the plates that the clamp is clamping aren't strong enough ?
Thank you for your comment again.
Yes that's what I meant,, it's carbon steel material.
what calc are you doing (on the plates) to make you think you're crushing them ?
Are you using the right strength for your material? Carbon steel comes in a wide range of strengths. Common structural steel starts at 36ksi yield while HSLA steel commonly used for lifting equipment is 100ksi.
Hi YOUNGTAKI
How have you established a 1.5 to 2 safety factor in the clamped components?
The manufacturer has designed those clamps to work on structural beams and I would think that They would have considered the steel grades of the beams etc before setting torque values for the clamps.a
Hello all
I ran FEA to see SF on the carbon steel member.
I used Carbon steel yield limit = 46000 PSI
The carbon steel surface area that bolt contacts to : 0.3in^2
Applied preload = 10440 lbf (109 lb-in)
Stress = 34800 psi
SF = 1.3
Thank you for the information on HSLA steel
Hi YOUNGTAKI
I thought it would be the area of the clamp surface in contact with the carbon steel and not the bolt head, I also assumed that the area of the clamp in contact with the carbon steel would be larger than that of the bolt head. If this joint is purely static I don’t see a problem in any case.
Maybe the safety factor they are quoting is based on UTS and conventional analysis?
why run FEA when you're doing a hand calc (or are you checking your FEA ?)
Is fty the appropriate failure mode ?
