rsbmusicguy
- Mar 21, 2019
- 44
Hey all,
I am jacking a girder using a hydraulic jack to fix the respective bearing and due to the jacking load, I have to provide a double angle section at the web of the girder so the web does not buckle.
This is pretty typical for most of my jacking designs, my question is in regards to the bolts connecting the double angle to the girder web.
Do these connection bolts have to be designed for the full vertical jacking load (for shear and bearing, non slip critical connection)? If this is the case, I would have to provide a ton of bolts which will significantly reduce the area of my girder web. When I think of the double angles going into compression between the top and bottom flange of the girder, I am having trouble picturing the force transfer into the connection bolts at the web. I am looking for a way to justify not designing these connection bolts to take the full shear / bearing of the jacking force.
Let me know your thoughts, thanks!
RSB
RSB
