I have a 50,000 lb/hr high pressure boiler. In setting up the controls I have a dilemma. NFPA 85 calls for - 8 air changes, with the air dampers driven to their full open position- in one area, but in another section calls for only a- 15 seccond purge at prior setting air flows-with a boiler relight. My question is: Which shall apply and when? The 15 second purge seems too short under almost any conditions, but the eight air change requirement delays the restart significantly. Any thoughts appreciated.[/indent]
