Boiler feed pump
SA07
373
Hi
Can you plz confirm which material is recommended for the casing & impeller of a boiler feed pump flow 30 m3/h head 310 m temperature 120 deg C pH 8.5-9.5 ? Thks
before anyone can help you, you need to explain why the water pH is so high...
Refer to API-610 which may provide the design and material selection for BFW pump as you look for.
