BMX Problems
  • Thread starter Thread starter Mloew
  • Start date Start date
M
Mloew
Guest
Pro/Guru's,
I am looking for some help in solving a couple of problems I have not encountered before in Pro/ENGINEER 2001 in the Behavioral Modeler. I have a call logged with PTC and searched the knowledge base but I am hoping that I may get additional (or perhaps faster) help here.
Initially had problems with parameters from calculations performed in an analysis (relation) feature were part relations. This was due to the new relation UI. I fixed this, but am not happy about not being able to use the new UI.
Several variables that are calculated in a SOLVE routine would not be available as parameters for a subsequent sensitivity study. Any clue as to why this happens?
Also, during a sensitivity study, the graphs disappear after calculation. I tried using both the default graphing tool and Excel Linked. This was never a problem previously.
Any help would be appreciated. TIA.
Best regards,
Matthew Ian Loew
Luck is the residue of design.
Branch Rickey
What build of 2001 are you running?
Brad Hacker
ME CAD Admin
Zebra Technologies Corp.
Build: 2003240
Dell Precision 450 w/ 2 Gb RAM Win 200 Pro
Here are the equations in my relation analysis feature:
SOLVE
F_A1 + F_A2 + F_A3 + F_A4 = CURB_WEIGHT
F_A2 * (X2) + F_A3 * (X3) + F_A4 * (X4) = CURB_WEIGHT * (XCOG:FID_MASS)
(((F_A1 / K1) - (F_A2 / K2)) / ((F_A1 / K1) - (F_A4 / K4))) = R2
(((F_A1 / K1) - (F_A3 / K3)) / ((F_A1 / K1) - (F_A4 / K4))) = R3
FOR F_A1, F_A2, F_A3, F_A4
Best regards,
Matthew
Hiya Matt,
I had the same problem. A suggested workaround is to turn off the new relations feature in the config pro. Search for new_relations_ui and set it to no. This results in the omission of the new and improved ( and not particularly useful) relation dialog and gives you back the standard relation text editor.
As I said, its a workaround, but it works.
Best regards
Jim
can any one tell me where i can get help on Behavior modelling.
kujur11a,
Yes, Google is a good place to start as is the FAQ I created on eng-tips.com:
http://www.eng-tips.com/faqs.cfm?spid=554&sfid=784
Best regards,
Matthew Ian Loew
Branch Rickey
Hi All,
I'm bringing back this old thread.
I'm trying to do a sensitivity analysis where I plot a parameter created by some math in relations which is based on a dimension in my model.
In the sensitivity analysis dialog box, I can select the dimension I want to vary, but the only parameters available to plot are those created by dimensional analyses. In the list of available parameters, I don't see those created with relations.
Is it even possible to do what I want to do?
Cheers,
