Blockedit
  • Thread starter Thread starter Aldona
  • Start date Start date
A
Aldona
Guest
When double clicking on a block, the editor comes in front. When I don't want it to edited after all I click on the close button and says "no" to the question if I want to save, but the complete drawing is closed....without saving any suggestions.
Thanks in advance.
You can set BLOCKEDITLOCK <1>, which disallows opening of the Block Editor and editing of dynamic block definitions.
Cheers!
Hallo,
You have to close the blockeditor with the "close block editor" button in the editor window. If you trie to close it with the close button in the upper right corner of the screenand say no to the question whether to save it or not, it does not only close the block but the whole drawing without saving.;)
