R
rvt3d
Guest
Hey all,
I can't tell the protusion from where to where I need the protusion.
This is what I do, I am in assembly mode:
1) Create component in assembly mode,
2) Type = Part, sub-type Solid
3) Creation Options I select 'Create Features'
Then I will start creating the protusion on planes of my skeleton.
It's a simple on, using the edges of a surface from datum plane to datum plane.
After I am done it only gives me the option: Blind
Normally I would get (if I make a protusion in a part) to go from-to or
more options so O constrain the length of my protusion using the datum
planes.
What does cauze this?
I read the manuel but properly overlooked something, but I ain't sure what?
cheers,
Ries
planes.
cheers,
Ries
