I have to design a small composite steel-concrete bridge for 24 ton trucks and due to the high live load i need to design the slab with continuity over the transverse beams.
My question is: since the continuity will create tensile stresses on the top part of the slab on the slab direction and this portion of concrete is compressed on the beam direction, isn't unsafe to use the concrete fck for the beam strength without consider the reduction due to biaxial stress?
I suppose that is acceptable, since the codes do not cite any reduction and the books(at least the ones that i saw) do not treat this question, but i cannot see how i can neglect this effect.
Thank you.
Thank you.
