Bevel on the head of a hex nut
  • Thread starter Thread starter Senor Dorado
  • Start date Start date
S
Senor Dorado
Guest
Just learning the Pro E techniques, and I'm stumped on how to create the little bevel on the head of a hex nut, using a revolved cut.
I have created the hex nut on the right datum plane with the top datum plane facing towards the top. The nut is 7.5mm deep and 15mm high from the bottom flat to the top flat. I used a hex shape from the palette in sketcher and used the intersection of the front and top datum planes as its origin.
Can someone give me a pointer or two in the right direction.
Keep a cool breeze
Senor Dorado
Sanjee
Thanks for the part. I needed to choose the correct datum plane (top in my case) and make a center line for the axis of rotation. Appreciate your prototype.
Senor Dorado
